c'est lequel le mieux ?
Publié : sam. 2 juil. 2005 16:24
voilÀ , j'ai vu ca sur wotm.com et je voulais savoir lequel est le plus puissant et le plus fiable ?d'ailleur je crois qu'une certaine personne connait un des 3 modÈles !!
dÉsolÉ je parle pas un mot d'anglais, d'ou ma question, je ne comprend rien a ce qui est Écrit !!
_____________________________________________________________
This kit is not only capable of building well beyond 750rwhp, and it slaughters Venom 650R Vipers for snacks too. This kit also has quality looks as well. (pictured is the HKS kit installed on a 2JZGTE hanging from a engine hoist, beautiful!..go ahead click on the pic for a big shot). Guilly's HKS GT2835 twin car with a small single fogger shot of nitrous did 875RWHP on this kit with cams! Stacey Barnett made 865rwhp with this kit as well with a small shot of NOS!!!
(2) HKS GT-Series ball bearing turbos 71mm compressor wheel, .50 exhaust a/r, 51.2mm exh.wheel HKS header, Heat Shields HKS downpipe 2 into 1 (2) HKS wastegates Oil feeds & returns w/ all the correct fittings Dual HKS intake pipes w/ HKS filters, rubber fittings & clamps, miscellaneous installation fittings. BOV's (optional at additional cost)
In order to build this level of HP, upgraded fuel systems, additional electronics,camshafts and tuning are required.
et voici le T78
Best bang-for-the-buck single turbo upgrade for a 6-speed 93.5-98 Supra.
Can be used on a automatic with nitrous or a 3200 rpm high stall torque converter. Not recomended for autocross use as this is a big horsepower turbo capable of 800+++ hp.
The kit includes:
GReddy stainless steel turbo exhaust manifold
GReddy (Mitsubishi) T78 turbine (very robust)
GReddy Wastegate
GReddy Intake System
All piping and plumbing lines
Comes with a stubby downpipe which can be adapted to your current stock twin turbo car downpipe (rmm, sp, tanabe) for around $100 at your local muffler shop.
et le T88
This kit has been used in Japan for 5 years on Supras and has extensive tuning experience behind it. One of the greatest kits there is. If you want a wailing, top-end crusher, then this is your turbo. It flows enough air for approximately 850rwhp and according to Jon Kurayama from Fastrax Turbo's it has one of the most robust turbo's he has seen. Incredible GReddy quality with every part you need for a clean install. This is not suitable for an automatic car, unless you run nitrous or a 4200 rpm stall convertor. The Titan Motorsports Supra run a T88H Greddy Turbo and kit!!!
et voici le T78
The kit includes:
GReddy Wastegate
et le T88
