[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 368: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 652: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/session.php on line 942: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3633: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3635: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3636: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3637: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
Supracars • Afficher le sujet - [MKIII] Ma Supra Turbo (nouvelles photos p27)
Nous sommes le Dim 28 Juin 2026 08:36
Poster un nouveau sujet Répondre au sujet  [ 570 messages ]  Aller à la page Précédent  1 ... 34, 35, 36, 37, 38
 Sujet du message: Re: [MKIII] Ma Supra Turbo (nouvelles photos p27)
Nouveau messagePosté: Ven 21 Fév 2014 20:01
vos attentes:
Régulateur de pression d'essence installé , premier démarrage avec de l'E85 richesse a plus de 10 afr avec 10% de richesse en plus via safc , alors qu'avant avec +10% jetait a 12.5 , une sacrée différence reste a tester sur la route .
par , sur Flickr
Supra Forever
Nouveau messagePosté: Sam 22 Fév 2014 04:54
vos attentes:
C'est quand même très étonnant qu'il te faille une pression d'essence plus élevée avec un CT26 d'origine... :roll:
Nouveau messagePosté: Sam 22 Fév 2014 10:57
vos attentes:
Pour éviter les fuel cut à l'E85 ^^
Et ça permet de monter plus haut en pression turbo en réduisant la valeur du débitmètre. Et comme le moteur pense qu'il y a moins d'air, il met plus d'avance ^^ Avec l'E85 c'est tout benef.
Nouveau messagePosté: Sam 22 Fév 2014 12:09
vos attentes:
Supra Forever
Nouveau messagePosté: Sam 22 Fév 2014 12:29
vos attentes:
Les FCD sont des grosses cochonneries. Ils retirent le fuel cut, certes, mais ne donnent pas un bon dosage pour autant, le moteur tourne nickel mais moins riche, ce qui fait chauffer le turbo. En plus l'allumage reste à son avance de fuel cut, du coup on se retrouve vite avec trop d'avance et le calculateur en chie à réguler.
Un moteur turbo doit rester aussi riche qu'à l'origine si on a pas d'EGT pour contrôler.
Nouveau messagePosté: Sam 22 Fév 2014 14:21
vos attentes:
C'est bon tout ça :D
Tu disais plus tôt dans la semaine 700 grammes donnent 350CV?
Le tube en J, faut le virer quand on change pompe et régulateur je crois, ça peut être une explication.
Pour le fuel cut, je rejoins Proger.
Nouveau messagePosté: Sam 22 Fév 2014 23:07
vos attentes:
Nouveau messagePosté: Dim 23 Fév 2014 14:10
vos attentes:
Supra Forever
Nouveau messagePosté: Dim 23 Fév 2014 22:20
vos attentes:
Nouveau messagePosté: Lun 24 Fév 2014 03:34
vos attentes:
Nouveau messagePosté: Lun 24 Fév 2014 09:04
vos attentes:
Supra Forever
Nouveau messagePosté: Lun 24 Fév 2014 12:27
vos attentes:
Nouveau messagePosté: Lun 24 Fév 2014 16:15
vos attentes:
Nouveau messagePosté: Jeu 1 Mai 2014 22:48
vos attentes:
Des petite news de la cuicui mobile , récemment j'ai passé ma supra au CT (quel a passé sans problème) et pour se faire elle est resté moteur tournant un certain temps et une fois le contrôle fini mon problème de démarrage est revenu , obligé de passer la première pour sortir la supra du CT a l'aide du démarreur et la elle a fini par démarrer .
Donc suite a se problème j'ai effectué un check engine et résultat défaut N°14 (défaut signal IGF ) .
Suite a ça j'ai nettoyer les prise au niveau de l'allumage sans savoir si cela a suffit , j'aimerai savoir si quelqu'un aurais une autre piste a suivre pour se défaut qui ne survient que lorsque que la température du compartiment moteur est trop élevé (oui lorsque qu'il fait 30° dehors moteur froid mais que la voiture reste au soleil elle refuse aussi de démarrer ) .
Petit rappel du problème en vidéo
Merci d'avance amis supraïste .
Supra Forever
Nouveau messagePosté: Ven 2 Mai 2014 19:33
vos attentes:
D'après moi c'est certainement un problème de faisceau... (ça craquèle avec l'age :P)
Essaye de suivre les fils du boitier d'allumage.
Poster un nouveau sujetRépondre au sujet  [ 570 messages ]  Aller à la page Précédent  1 ... 34, 35, 36, 37, 38
